查看: 4487|回复: 0
[讨论] 材料明细表数量列→配置/数量→只能手工改为数量。
发表于 2016-6-25 09:59:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下图中的默认/数量,找了半天也没找到解决办法,只能手改为“数量”
SW材料明细表模板问题 SOLIDWORKS-iCAx开思论坛 - www.iCAx.org  https://www.icax.org/thread-401864-1-1.html
找了半天
SW的材料明细表不能去除“数量”一列-SolidWorks-三维网 - Powered by Discuz!  https://www.3dportal.cn/discuz/forum.php?mod=viewthread&tid=846587&highlight=%B2%C4%C1%CF%C3%F7%CF%B8%B1%ED%2B%C1%D0%2B%CA%FD%C1%BF
2011 SOLIDWORKS 帮助 - 在材料明细表中显示配置特定数量  https://help.solidworks.com/2011/chinese-simplified/SolidWorks/sldworks/AllContent/SolidWorks/Core/Detailing/t_bomsDisplaying_Configuration-specific_Quantities.htm?id=85df7592a989440490e4b1bfdd1af128#Pg0&ProductType=&ProductName=
2016 SOLIDWORKS 帮助 - 更改在材料明细表中显示的配置数量  https://help.solidworks.com/2016/chinese-simplified/solidworks/sldworks/t_changing_configuration_quantities_bom.htm
GMT+8, 2025-4-29 15:02 , Processed in 0.033269 second(s), 12 queries , Gzip On, Redis On.
