查看: 5630|回复: 8
[求助] 求教大神两个录制的宏怎么合成一个
发表于 2016-7-27 16:29:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我想为SOLIDWORKS钣金的平板形式定制一个快捷键,分别录制了解压平板形式和压缩平板形式两个宏,两个宏作为两个快捷键,这样钣金展开和折叠要使用两个快捷键,我想一键就实现展开和压缩,但不会合并这两段宏,求大神帮忙。下面是两个宏:
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("平板型式11", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Part.EditSuppress2
boolstatus = Part.Extension.SelectByID2("平板型式", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
End Sub
Sub main()
Set swApp = _
Part.EditUnsuppress2
End Sub
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2016-7-28 00:26:44 | 只看该作者
试试这个,如用繁体要改名称
  1. Dim swApp As Object
  2. Dim part As Object
  3. Dim boolstatus As Boolean
  4. Dim swSelMgr  As SldWorks.SelectionMgr
  5. Dim swFeat    As SldWorks.Feature
  6. Dim vConfNameArr  As Variant
  7. Dim vSuppStateArr  As Variant
  8. Dim i As Integer
  9. Sub main()
  10. Set swApp = Application.SldWorks
  11. Set part = swApp.ActiveDoc
  12. boolstatus = part.Extension.SelectByID2("平板型式1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
  13.
  14.   Set swSelMgr = part.SelectionManager
  15.   Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
  16.    vConfNameArr = part.GetConfigurationNames
  17.     vSuppStateArr = swFeat.IsSuppressed2(swThisConfiguration, vConfNameArr)
  18.   Debug.Assert 0 = UBound(vSuppStateArr)
  19.
  20.    vSuppStateArr = swFeat.IsSuppressed2(swAllConfiguration, vConfNameArr)
  21. Debug.Assert UBound(vSuppStateArr) = UBound(vConfNameArr)
  22.
  23. vSuppStateArr = swFeat.IsSuppressed2(swSpecifyConfiguration, vConfNameArr)
  24. Debug.Assert UBound(vSuppStateArr) = UBound(vConfNameArr)
  25. For i = 0 To UBound(vConfNameArr)
  26.         Debug.Print "    " & vConfNameArr(i) & " ---> " & vSuppStateArr(i)
  27.     If (vSuppStateArr(i) = False) Then
  28.     part.EditSuppress
  29.      ElseIf (vSuppStateArr(i) = True) Then
  30.      part.EditUnsuppress
  31.     End If
  32. Next i
  33. part.ClearSelection2 True
  34. End Sub
复制代码
发表于 2016-7-28 09:27:52 | 只看该作者
运行后26行出错
发表于 2016-7-28 11:18:11 | 只看该作者
"平板型式"名称不一致造成的
发表于 2016-7-28 11:44:57 | 只看该作者
  8. Dim i As Integer
  9. Dim ii As Integer
  10. Dim nn As Integer
  11. Sub main()
  12. Set swApp = Application.SldWorks
  13. Set part = swApp.ActiveDoc
  14. With part
  15. nn = .FeatureManager.GetFeatureCount(True)
  16. Set swFeat = .FirstFeature
  17. Debug.Print swFeat.GetTypeName
  18. For ii = 1 To nn - 1
  19. Set swFeat = swFeat.GetNextFeature
  20. Debug.Print swFeat.GetTypeName, swFeat.Name
  21. If swFeat.GetTypeName = FlatPattern Then Exit For
  22. Next ii
  23. End With
  24. boolstatus = part.Extension.SelectByID2(swFeat.Name, "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)    '选择平板型式特征
  25.   Set swSelMgr = part.SelectionManager
  26.   Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
  27.    vConfNameArr = part.GetConfigurationNames
  28.    vSuppStateArr = swFeat.IsSuppressed2(swThisConfiguration, vConfNameArr)
  29.   Debug.Assert 0 = UBound(vSuppStateArr)
  30.
  31.    vSuppStateArr = swFeat.IsSuppressed2(swAllConfiguration, vConfNameArr)
  32.     Debug.Assert UBound(vSuppStateArr) = UBound(vConfNameArr)
  33.
  34. vSuppStateArr = swFeat.IsSuppressed2(swSpecifyConfiguration, vConfNameArr)
  35. Debug.Assert UBound(vSuppStateArr) = UBound(vConfNameArr)
  36. For i = 0 To UBound(vConfNameArr)
  37.     Debug.Print "    " & vConfNameArr(i) & " ---> " & vSuppStateArr(i)
  38.     If (vSuppStateArr(i) = False) Then
  39.     part.EditSuppress
  40.     ElseIf (vSuppStateArr(i) = True) Then
  41.     part.EditUnsuppress
  42.     End If
  43. Next i
  44. part.ClearSelection2 True
  45. End Sub
复制代码
发表于 2016-7-28 15:43:04 | 只看该作者
学习一下
发表于 2016-7-28 17:01:05 | 只看该作者
试了一下,展开没问题,但是有些钣金零件折叠不回去,这是为什么?
发表于 2016-7-28 17:19:55 | 只看该作者
上part 看下
发表于 2016-8-2 18:16:25 | 只看该作者
做了一个简单的钣金件,试了一下五楼的宏代码,运行没问题。
谢谢pyczt大大共享源代码。
GMT+8, 2025-4-9 16:11 , Processed in 0.028422 second(s), 12 queries , Gzip On, Redis On.
