查看: 16516|回复: 6
UG/OPEN API中的网格划分函数的参数类型如何知道?
发表于 2004-3-17 12:07:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UG/OPEN API中的函数UF_SF_create_2d_mesh和UF_SF_create_2d_ansys_mesh,他们的参数各有一个为结构体类型,
函数原型定义分别如下:
extern int UF_SF_create_2d_ansys_mesh (
UF_SF_AMM_mesh_parameters_t * mesh_params,
char * element_type,
int num_objects,
tag_t * object_id,
tag_t * mesh_tag );
和
extern int UF_SF_create_2d_mesh (
int num_objs,
tag_t * objs_p,
int num_hard_pnts,
tag_t * hard_pnts_p,
UF_SF_sfqm_mesh_data_t * mesh_data,
tag_t * mesh_recipe );
其中:
UF_SF_AMM_mesh_parameters_t 和
UF_SF_sfqm_mesh_data_t 的原型怎么查到?
谢谢!
发表于 2004-3-17 13:05:46 | 只看该作者
struct UF_SF_AMM_mesh_parameters_s
Overview
Data Members
element_descritor_tag
tag_t element_descritor_tag
Mesh attributes related to model geometry Type of Element to create
mesh_dimension
UF_SF_mesh_dimension_t mesh_dimension
2D(shell) or 3D(solid)
ansys_area_element_shape
int ansys_area_element_shape
The area element shape tri/quad
midnode_needed
int midnode_needed
0 = OFF , 1 = ON
smart_edge_seeding
int smart_edge_seeding
smart edge seeding 0 = OFF, 1 = ON
overall_elem_size
double overall_elem_size
Overall Element Size
area_transition_factor
double area_transition_factor
Maximum Area Transition Factor
area_transition_lower_limit
double area_transition_lower_limit
area_transition_upper_limit
double area_transition_upper_limit
area_expansion_factor
double area_expansion_factor
Area Expansion Factor
area_expansion_lower_limit
double area_expansion_lower_limit
area_expansion_upper_limit
double area_expansion_upper_limit
volume_expansion_factor
double volume_expansion_factor
Volume Expansion Factor
volume_expansion_lower_limit
double volume_expansion_lower_limit
volume_expansion_upper_limit
double volume_expansion_upper_limit
edge_matching_tol
double edge_matching_tol
UG edge matching tolerance
jacobian_ratio
double jacobian_ratio
for midnode snapping - threshold
warp
double warp
for quad splitting - threshold
do_not_format_mesh
int do_not_format_mesh
0 = OFF , 1 = ON
split_quad_toggle
int split_quad_toggle
0 = OFF , 1 = ON
midnode_snapping
int midnode_snapping
0 = OFF , 1 = ON
smart_sizing
int smart_sizing
0 = OFF , 1 = ON
quad_splitting
int quad_splitting
0 = OFF , 1 = ON
smoothing
int smoothing
0 = OFF , 1 = ON
cleanup
int cleanup
0 = OFF , 1 = ON
debugging
int debugging
0 = OFF , 1 = ON
journaling
int journaling
0 = OFF , 1 = ON
mapped_mesh
int mapped_mesh
0 = OFF , 1 = ON
struct UF_SF_sfqm_mesh_data_s
Overview
Data Members
elem_type
UF_SF_sfqm_elem_type_t elem_type
The type of element chosen.
elem_size
double elem_size
The size of the element.
smart_edge_seeding
mesh_param_data_p
UF_SF_sfqm_param_data_p_t mesh_param_data_p
Pointer to the mesh parameter data structure, containing the values for the given parameters.
do_not_format_mesh
0 = OFF , 1 = ON
mapped_mesh
int mapped_mesh
0 = OFF , 1 = ON
发表于 2004-3-17 13:55:10 | 只看该作者
非常感谢tsingtsang 侠士,我的help里面没有,还有很多函数的参数都找不到,请问您是怎么找到的。有没有这方面的书籍?
向您鞠躬!
发表于 2004-3-17 17:06:19 | 只看该作者
就是help里的东东,对应function的头文件里的结构体定义
书没有很合适的
发表于 2004-3-18 19:52:47 | 只看该作者
谢谢tsingtsang ,我在help里面搜索,一直没有找到他的定义,在ugopen文件夹下的.h文件里。多谢了!
发表于 2009-5-20 09:53:15 | 只看该作者
为什么,我用UF_SF_create_2d_mesh这个函数就是不能产生网格了?
发表于 2009-5-20 09:57:35 | 只看该作者
为什么我用UF_SF_create_2d_mesh就是不能产生网格啊!
GMT+8, 2025-4-7 23:44 , Processed in 0.022632 second(s), 12 queries , Gzip On, Redis On.
