Rubber-like amber (TangoPlus FLX930) 透明类像胶材料
2013-6-18 13:25| 查看: 29440| 评论: 0
摘要: 性能指标 标准测试方法 TangoBlackPlus / TangoPlus 拉伸强度,MPa D-412 1.8 – 2.4 极限拉伸率,% D-412 170 – 220 压缩永久变形,% D-395 4 – 5 肖氏硬度,Scale A D-2240 26 – 28 撕裂强度,Kg/cm ...
撕裂强度,Kg/cm D-624 2.4
玻化温度,Tg DSC (-80℃ - +100℃) -9.6
Ross Flex D-1052 >150,000
GMT+8, 2025-4-28 08:29 , Processed in 0.013505 second(s), 9 queries , Gzip On, Redis On.
