查看: 2362|回复: 2
[求助] 一键删除边界框的宏
发表于 2017-6-11 11:20:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
录制了一个一键删除边界框的宏,代码如下。这个宏只能对应删除切割清单项目1~15的边界框,超出范围的删不了,当然笨办法是有:一直从切割清单项目1列到切割清单项目100、1000等,所以,想搞一个循环语句遍历所有的切割清单项目,苦于编程水平太差,求论坛各位高手指教,谢谢!
  1. Dim swApp As Object
  2. Dim Part As Object
  3. Dim boolstatus As Boolean
  4. Dim longstatus As Long, longwarnings As Long
  5. Sub main()
  6. Set swApp = Application.SldWorks
  7. Set Part = swApp.ActiveDoc
  8. boolstatus = Part.Extension.SelectByID2("实体", "BDYFOLDER", 0, 0, 0, False, 0, Nothing, 0)
  9. Part.ClearSelection2 True
  10. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目1", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  11. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目2", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  12. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目3", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  13. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目4", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  14. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目5", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  15. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目6", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  16. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目7", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  17. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目8", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  18. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目9", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  19. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目10", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  20. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目11", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  21. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目12", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  22. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目13", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  23. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目14", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  24. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目15", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  25. Part.EditDelete
  26. End Sub
复制代码
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2017-6-11 18:10:24 | 只看该作者
不太明白楼主的意图,随手改下,可能不是楼主想要的。
  5. Dim i As Integer
  6. Sub main()
  7. Set swApp = Application.SldWorks
  8. Set Part = swApp.ActiveDoc
  9. boolstatus = Part.Extension.SelectByID2("实体", "BDYFOLDER", 0, 0, 0, False, 0, Nothing, 0)
  10. Part.ClearSelection2 True
  11. For i = 1 to 1000
  12. boolstatus = Part.Extension.SelectByID2("边界框_切割清单项目" & i, "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
  13. Next
  14. Part.EditDelete
  15. End Sub
复制代码
参与人数 1技术 +1 贡献 +10 收起 理由
小小豬 + 1 + 10 神马都是浮云
发表于 2017-6-11 21:48:38 | 只看该作者
谢谢莱大提供的代码!使用一切正常,太感谢啦
GMT+8, 2025-10-18 10:52 , Processed in 0.024548 second(s), 19 queries , Gzip On, Redis On.
