【讨论】Surfcam Mpost, LPost, EPost 疑難雜症
发表于 2003-10-15 00:42:01 | 只看该作者
vip wrote:
唉我也弄不太清楚我是用哪个后处理,反正每次我都是选FANUC,再点POST,它就自动后处理了,如果要贴是否要把POSTLIB这个文件夹整个贴上来啊?1.65MB,不小哇.
用文本編輯器把 surfcam/surf2001/surfcam.pst 打開..
看二軸 或 三軸  你挑的Fanuc是哪個...用Mpost 還是 SPost..
對應的檔案 在哪裡?
32
发表于 2003-10-15 21:02:34 | 只看该作者
档案如下:
#                               SURFCAM Version 2001                          #
#                          Post Menu Configuration File                       #
BeginPost EDM Default:1
PostItem List all
         Status Display all posts in postform.e
         ChDir   "c:\Surfcam\SURF2001\MPOST"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n"
         Task    "c:\Surfcam\SURF2001\SEDIT\SEDIT" "%p%N.ncc"
PostItem AGIE
         Status Agie
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 1
PostItem CHARMILLES
         Status Charmilles
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 2
PostItem MITSUBISHI
         Status  Mitsubishi H Series
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 3
PostItem SODICK
         Status Sodick
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 4
PostItemX CHARMILLES 4 Axis
          Status Charmilles 4 Axis
          Delete  "%p%N.NCC"
          Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 5
PostItemX MITSUBISHI 4 Axis
          Status Mitsubishi 4 Axis
          Delete  "%p%N.NCC"
          Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 6
PostItemX SODICK 4 Axis
          Status Sodick 4 Axis
          Delete  "%p%N.NCC"
          Command "c:\Surfcam\SURF2001\MPOST\EPOSTWIN" "%p%n" 7
PostItem APT-CL
         Status APT Cutter Location
         Command "c:\Surfcam\SURF2001\INC2APT" -d -I "%p%n" -O "%p%N.apt"
         Task    "c:\Surfcam\SURF2001\SEDIT\SEDIT" "%p%N.apt"
EndPost
BeginPost Lathe Default:1
PostItem List all
         Status Display all posts in postform.l
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n"
PostItem FANUC
         Status FANUC Model 10T
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n" 1
PostItem HAAS
         Status HAAS HL Series
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n" 2
PostItem MORI SEIKI
         Status MORI SEIKI MF series
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n" 3
PostItem OKUMA
         Status OKUMA OSP Series
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n" 4
PostItem GE 550
         Status GE 550
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\LPOSTWIN" "%p%n" 5
PostItem MILL/TURN
         Status  MILL/TURN POST PROCESSOR
         Command "c:\Surfcam\SURF2001\INC2APT" -op -b -I "%p%n" -O "%p%N.apt"
         ChDir   "c:\Surfcam\SURF2001\SPOST"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 75 "%p%N.ncc"
PostItem APT-CL
EndPost
BeginPost 2 Axis Default:1
PostItem List all
         Status Display all posts in postform.m
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n"
PostItem FANUC
         Status FANUC Model 15M-B
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n" 1
PostItem HAAS
         Status HAAS VF Series
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n" 2
PostItem FADAL
         Status FADAL Format 1
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n" 3
PostItem DYNAPATH
         Status DYNAPATH Delta 30
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n" 4
PostItem MAZAK
         Status MAZAK M2
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\MPOST\MPOSTWIN" "%p%n" 5
PostItem APT-CL
         Status  APT Cutter location
EndPost
BeginPost 3 Axis Default:1
PostItem List all
         Delete  "%p%N.NCC"
PostItem FANUC
         Status FANUC 15M-B
         Delete  "%p%N.NCC"
PostItem HAAS
         Delete  "%p%N.NCC"
PostItem FADAL
         Delete  "%p%N.NCC"
PostItem DYNAPATH
         Delete  "%p%N.NCC"
PostItem MAZAK
         Status MAZAK M2
         Delete  "%p%N.NCC"
PostItem NURB
         Status FANUC Style NURB
         Command "c:\Surfcam\SURF2001\INC2APT" -I "%p%n" -O "%p%N.apt"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 69 "%p%N.ncc"
PostItem APT-CL
EndPost
BeginPost 4 Axis Default:1
PostItem List all
         Delete  "%p%N.NCC"
PostItem FANUC
         Status  FANUC 15M-B
         Command "c:\Surfcam\SURF2001\INC2APT" -w -5 -I "%p%n" -O "%p%N.apt"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 05 "%p%N.ncc"
PostItem HAAS
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 15 "%p%N.ncc"
PostItem FADAL
         Status  FADAL Format One
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 20 "%p%N.ncc"
PostItem DYNAPATH
         Status  DYNAPATH Conversational
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 25 "%p%N.ncc"
PostItem MAZAK
         Status  MAZAK M2
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 30 "%p%N.ncc"
PostItem APT-CL
EndPost
BeginPost 5 Axis Default:3
PostItem Bridge Mill
         Status  Vertical Bridge Style Mill- Dual Rotary Head
         Command "c:\Surfcam\SURF2001\INC2APT" -w -5 -op -f 1 -r 45 -I "%p%n" -O "%p%N.apt"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 80 "%p%N.ncc"
PostItem Dual Rotary Table
         Status  Dual Rotary Table Mill - AB configuration
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 85 "%p%N.ncc"
PostItem Laser Contouring
         Status  5 Axis Laser Contouring Post
         Command "c:\Surfcam\SURF2001\INC2APT" -w -5 -b -f 1 -r 45 -I "%p%n" -O "%p%N.apt"
         Delete  "%p%N.NCC"
         Command "c:\Surfcam\SURF2001\SPOST\SPOSTM" "%p%N.apt" 90 "%p%N.ncc"
PostItem APT-CL
        Command "c:\Surfcam\SURF2001\INC2APT" -d -w -5 -r 45 -I "%p%n" -O "%p%N.apt"
EndPost
############################ Setup sheet ######################################
  SetupSheet             "c:\Surfcam\SURF2001\sview" -m SSHEET.TXT             #
############################ INC Filters ######################################
  IncFilter               "c:\Surfcam\SURF2001\FILTERS\ArcFltr.dll"
#IncFilter               "c:\Surfcam\SURF2001\FILTERS\ArcFltrMx.dll"          #
  IncFilter               "c:\Surfcam\SURF2001\FILTERS\NurbFltr.dll"
####################### SURFCAM.PST general description #######################
# This file is used to configure the NC Post commands for each NC Mode.       #
# Lines that begin with a # contain comments which are ignored when read.     #
# Each NC Mode section must begin with a line 'BeginPost <name> Default:<n>'  #
#       <name> is the name of the NC Mode.                                    #
#       <n> is the number of the default post item (initial list selection)   #
# Each Post Must begin with a line 'PostItem <name>'                          #
# The <name> is used to select the post from a list of posts for each NC Mode.#
# Each post item is followed by lines of Post Commands to execute the post.   #
# Each command line consists of a command keyword followed by command string. #
########################### NC Post commands ##################################
# Command                  Description                                        #
# Status    <status>       Provides one line of help for each post item       #
# ChDir     <dir>          Changes Directory to make <dir> current directory  #
# Command   <cmd>          Executes sequential list of a particular commands. #
# Task      <cmd>          Executes win apps for multi-tasking within SURFCAM #
# Delete    <file>         Delete temporary file.                             #
# Rename    <file>         Rename file.                                       #
# CopyFile  <file>         Copy file.                                         #
######################### Command line variables ##############################
# Variables                Description                                        #
# %p                       256 character path                                 #
# %q                       8 character path                                   #
# %n                       256 character file name                            #
# %s                       8 character file name                              #
# %N                       256 character file name without extension          #
# %S                       8 character file name without extension            #
########################### INC2APT switches ##################################
# Switch                   Description                                        #
# -w                       Output WORLD coordinates                           #
# -m                       Output inverted MCS matrix                         #
# -5                       Output I,J,K vectors with all GOTO/ commands       #
# -op                      Output OPERTN/ commands                            #
# -P                       Output Tool Pre-select command                     #
# -b                       Output ROW/START and ROW/END commands              #
# -d                       Display INC2APT dialog                             #
# -toolinfo                Output Tool comment from library                   #
# -n                       Output RAPID0 and RAPID1 commands                  #
# -x                       Output GOTO/ commands at any quadrant              #
# -c                       Check to see if existing file exists               #
# -cview                   Output Cview number and name                       #
# -event                   Output event records                               #
# -debug                   Output debug data                                  #
# -far                     Output redundant REDRAT/ command after RAPID       #
# -f angle                 Output GOTO/ commands at a defined angle           #
# -r angle                 Output GOTO/ commands at a defined angle           #
# -Precision value         Define X,Y,Z coordinate precision                  #
# -Vprecision value        Define I,J,K vector precision                      #
# -I Input path            Define input path(e.g. ""%p%n"")                   #
# -O Ouput path            Define output path(e.g. "d:\surfcam\APT")          #
33
发表于 2003-10-15 22:58:25 | 只看该作者
用文本編輯器 將Surfcam\postlib\postform.m 打開
編輯第一個 Fanuc 15M  將 紅色 部分刪除
StartCode                                   # Start of the program
%0
O[0]   <----- 刪除
$[0]
^[0]
&[0] *[0]  <----------到此
G17 G40 G80 G90
End
1stToolChange                               # First tool change
T[Tool] M6   <-------  刪除
M[Direct] S[Speed]
G0 G[54] X[H] Y[V]
G43 Z[D] H[Lcomp]
M[Cool]
End
Infeed                                      # Enable cutter comp
G[Side] X[H] Y[V] D[DComp] F[FRate]
end
Outfeed                                     # Disable cutter comp
G1 G40 X[H] Y[V]
end
ToolChange                                  # Secondary tool changes
M9
G49 Z0 M5
T[Tool] M6
M[Direct] S[Speed]
G0 X[H] Y[V]
G43 Z[D] H[Lcomp]
M[Cool]
End
EndCode                                     # End of the program
M9
G90 G0 G49 Z0 M5
X0 Y0
M30
%0
End
34
发表于 2003-10-19 22:10:15 | 只看该作者
俺去试试
谢过版主先。
35
发表于 2003-10-19 22:30:16 | 只看该作者
版主
好象有很多个T[TOOL]M6
是否都删掉?
36
发表于 2003-10-19 22:37:28 | 只看该作者
嘿嘿
版主真是高人
这下省去俺每次写完程式删除的麻烦喽
谢就一个字我只说一次~~
37
发表于 2003-10-29 13:07:24 | 只看该作者
PostForm.M 裡的 每個 Name xxxxx 代表一個後處理機器配置文件
應該說他是你所有有用到的後處理機器配置文件的總成文件
在postlib/mpost/ 下的那些 xxxxx.m3, xxxx.m4, xxxx.l2, xxxx.e2, xxxx.e4 是各個後處理配置文件的 樣版
Surfcam.pst裡的 是 所有後處理 命令的批次文件總成
38
发表于 2004-12-7 12:06:40 | 只看该作者
请问:做五轴的后置处理怎么出不来?
发表于 2004-12-10 10:26:30 | 只看该作者
zzhzzhzzh wrote:
请问:做五轴的后置处理怎么出不来?
把你的Surfcam2003\surf2003\surfcam.pst 貼上來..
我看看..
40
发表于 2004-12-10 11:33:59 | 只看该作者
帮我看看,谢谢!
GMT+8, 2025-4-29 18:20 , Processed in 0.040127 second(s), 10 queries , Gzip On, Redis On.
