查看: 21195|回复: 32
【推荐】一个英文的pro/e NC好论坛!
发表于 2004-11-7 12:25:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://www.mCADcentral.com/proe/forum/forum_topics.asp?FID=12
发表于 2004-11-7 12:25:59 | 只看该作者
不要忘了,这才是我们的家啊!
发表于 2004-11-7 13:07:24 | 只看该作者
;) 国内的破衣水平已经是难齐其项背了。。。比方ICEFAI,要达到他的境界,偶恐怕要好多年才行啊。。。。。
  不过,有空也去看一下,虽然偶英文只是半桶水。。。
发表于 2004-11-7 14:06:57 | 只看该作者
1.(引用)This cannot be done automatically in Pro/ENGINEER. THe cutting time can be retrieved from Manufacturing Info, or from GPOST, whichever is more accurate, and entered manually based on that. The cutting time from GPOST has the potential to be more accurate, anyway, depending upon the construction of the post.
I have submitted an enhancement request for this, and I know some of my colleagues have as well.
  内容好象是说计算刀路时间的两种方法,呵呵,我都还不会!
发表于 2004-11-7 17:54:31 | 只看该作者
偶去学学ENGLISH还可以!!!!
发表于 2004-11-7 19:52:31 | 只看该作者
看到一个关于切深和留痕高的问题,几个鬼老在哪儿讨论了几天
发表于 2004-11-7 20:02:15 | 只看该作者
    姐姐,何不翻译一下,贴来这里啊。。。。
发表于 2004-11-7 21:37:32 | 只看该作者
他们也在比较PROE/NC和MASTERCAM,有个家伙说他用PROE/NC25年了,乖乖不的了!!!
不过还有个家伙说用PROE编程的人还没有MASTERCAM的工资高他很奇怪!!!!
发表于 2004-11-7 22:03:04 | 只看该作者
     原来全世界的工程师都这么幽默。。。。
发表于 2004-11-7 22:05:56 | 只看该作者
Hi Lolo,
You have a few options:
这是他们说的用螺旋线锣圆孔的四种方法!!!!!LIUTIANLU
1- Thread mill (what Christopher suggested)
2- A volume sequence with a big step_depth that does a simple profile at the bottom (you can later in customize cut out the profile if needed). Use helical_diameter to make a helical plunge entry.
3- If you do not care about having an exact helical motion, but want just a continuous move all the way down the surface of the hole, try surface machining/ cutline with Scan_type = helical.
4- Make a helical curve and drive it using trajectory sequence.
GMT+8, 2025-4-19 20:07 , Processed in 0.028612 second(s), 12 queries , Gzip On, Redis On.
