[原创] 引领大家走进自动化编程的世界
发表于 2007-7-15 13:02:14 | 只看该作者
两个解决办法:
  1.你的宏没做好.
  2.可以点PM的"工具"--重设表格
22
发表于 2007-7-15 13:21:26 | 只看该作者
那是有些参数没有被取消。比如,你用了残留加工。下次写开粗刀路的时候它的勾是自动勾上的
23
发表于 2007-7-15 13:29:08 | 只看该作者
顶一下楼主,辛苦了
24
发表于 2007-7-15 13:45:01 | 只看该作者
原帖由 o198000 于 2007-7-15 12:59 发表
有时候我用宏完成一个铜公,下一个的时候非得重启PM才能正确,请兄弟们指教下,如何完成一个后怎样使PM回复到初始状态?
解决方法:在每段宏的首行添加上此命令:RESET ALL                            ( 重设表格)
如下macro程序所示:
RESET ALL        重设表格
dialogs message off
FORM BLOCK
EDIT BLOCK RESETLIMIT 0.01
EDIT BLOCK ALL UNLOCK
EDIT BLOCK RESET
EDIT BLOCK ZMIN LOCK
EDIT BLOCK RESETLIMIT 0.03
EDIT BLOCK RESET
EDIT BLOCK ZMAX LOCK
EDIT BLOCK RESETLIMIT -10
EDIT BLOCK RESET
BLOCK ACCEPT
CREATE PLANE ;
0.0
CREATE TOOL '12MM' ENDMILL EDIT TOOL '12MM' DIAMETER 12 FORM FEEDRATE EDIT PRATE 2500 EDIT FRATE 8888 EDIT RPM 8000 FEEDRATE ACCEPT
IMPORT TEMPLATE ENTITY TOOLPATH "Favourites\Raster-Finishing.ptf" FORM TOOLPATH
ACTIVATE TOOL "12MM"
RENAME TOOLPATH "1" "开粗--首次光顶"
EDIT FTOLERANCE "0.1"
FORM THICKNESS EDIT THICKNESS TAB GENERAL
EDIT FTHICKNESS AXIAL_RADIAL OFF
EDIT FTHICKNESS AXIAL_RADIAL ON
EDIT FTHICKNESS 0.0
EDIT FTHICKNESS AXIAL 0.0
THICKNESS APPLY
THICKNESS ACCEPT
EDIT FINRASTER STEPOVER "7.0"
ACTIVATE BOUNDARY " "
FORM LEADLINK
EDIT TOOLPATH LEADS PAGE ZHEIGHTS
EDIT TOOLPATH LEADS SKIMDIST 5
EDIT TOOLPATH LEADS PLUNGEDIST 5
EDIT TOOLPATH LEADS INCREMENT_FROM_STOCK Y
EDIT TOOLPATH LEADS RADIAL_CLEARANCE  0.0
EDIT TOOLPATH LEADS GOUGECHECK N
EDIT TOOLPATH LEADS GOUGECHECK Y
EDIT TOOLPATH LEADS PAGE FIRSTLEADIN
EDIT TOOLPATH LEADS SEPARATE_FIRSTLEADIN N
EDIT TOOLPATH LEADS SEPARATE_FIRSTLEADIN Y
EDIT TOOLPATH LEADS FIRSTLEADIN EXTENDED
EDIT TOOLPATH LEADS FIRSTLEADIN DISTANCE 20.0
EDIT TOOLPATH LEADS PAGE LASTLEADOUT
EDIT TOOLPATH LEADS SEPARATE_LASTLEADOUT N
EDIT TOOLPATH LEADS SEPARATE_LASTLEADOUT Y
EDIT TOOLPATH LEADS LASTLEADOUT EXTENDED
EDIT TOOLPATH LEADS LASTLEADOUT DISTANCE 20.0
EDIT TOOLPATH LEADS PAGE LEADIN
EDIT TOOLPATH LEADS LEADIN EXTENDED
EDIT TOOLPATH LEADS LEADIN DISTANCE 15.0
EDIT TOOLPATH LEADS LEADIN2 NONE
EDIT TOOLPATH LEADS PAGE LEADSOUT
EDIT TOOLPATH LEADS LEADOUT EXTENDED
EDIT TOOLPATH LEADS LEADOUT DISTANCE 15.0
EDIT TOOLPATH LEADS LEADOUT2 NONE
EDIT TOOLPATH LEADS PAGE LEADEXTENSIONS
EDIT TOOLPATH LEADS EXTIN NONE
EDIT TOOLPATH LEADS EXTOUT NONE
EDIT TOOLPATH LEADS PAGE LINK
EDIT TOOLPATH LEADS LINK THRESHOLD 100.0
EDIT TOOLPATH LEADS LINK TANGENT
EDIT TOOLPATH LEADS LONGLINK SKIM
EDIT TOOLPATH LEADS SAFELINK SAFEZ
EDIT TOOLPATH LEADS LINK MOVE_DIR TOOLAXIS
EDIT TOOLPATH LEADS RETRACTDIST  0.0
EDIT TOOLPATH LEADS APPROACHDIST  .0
EDIT TOOLPATH LEADS LINK ARCFIT Y
EDIT TOOLPATH LEADS LINK ARCFIT N
PROCESS TPLEADS
LEADS ACCEPT
EDIT FINRASTER ANGLE "0.0"
EDIT FINRASTER STARTCORNER LOWERLEFT
SET FINRASPER
UNSET FINRASPER
EDIT FINRASTER STYLE TWOWAY
EDIT FINRASTER ARCFIT ON
EDIT FINRASTER ARCFIT OFF
EDIT TOOLPATH "开粗--首次光顶" CALCULATE
FINISHING CANCEL
EXPLORER SELECT Model "Planes" NEW
DELETE MODEL "Planes"
EDIT TOOLPATH "开粗--首次光顶" REAPPLYFROMGUI
FORM FEEDRATE
EDIT RSPEED 10000
EDIT PRATE 2500
EDIT FRATE 1111
EDIT RPM 8000
EDIT DRILL FEED 0
RESET TOOLPATH FEEDRATE
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT TOOLPATH SAFEAREA SIZE  20
EDIT TOOLPATH SAFEAREA PLUNGE_SIZE  10
RESET TOOLPATH RAPID
TOOLZHEIGHTS ACCEPT
FORM DATUM
EDIT TOOLPATH START TYPE BLOCK
EDIT DATUM PAGE END
EDIT TOOLPATH END TYPE POINT_SAFE
RESET TOOLPATH START_END
DATUM ACCEPT
EXPLORER SELECT Level "Planes" NEW
DELETE LEVEL "Planes"
dialogs message on
如果不加RESET ALL   (重设表格)也行,则前提就是你的录制的步骤必须每一个选项框都要选取,如果你不要该工具栏的该功能,则必须先勾取,然后再去掉,这样,宏里就会出现这些你录制的程序步骤 ,也就是一个完整的宏(注:此种做法通常会有影响计算程序的速度)!
[ 本帖最后由 kugo 于 2007-7-15 13:58 编辑 ]
25
发表于 2007-7-15 13:47:45 | 只看该作者
详看楼主解释。顶下
26
发表于 2007-7-15 15:25:08 | 只看该作者
多谢指教!真是获益匪浅!
27
发表于 2007-7-15 15:51:35 | 只看该作者
兄弟不用这么客气,如果要源代码的话就本人就无能为力了(这是与公司的同事共同做的一个项目),但入门的方法可以告诉大伙,之前我也是用macro(宏)做的,但是这样限制太死,不能灵活运用且要做很多*.mac档,但是PM支持VB做二次开发,就可以加入变量了,如果要更专业级的就要找高人了.
先给个电极A的macro给大伙作参考,在VB里也只不过是格式有点不同和可加工变量而已.(pm7.0)版本:
RESET ALL
CREATE TOOL ; TIPRADIUSED FORM TOOL
EDIT TOOL "1" DIAMETER 6
EDIT TOOL "1"  TIPRADIUS 0.5
EDIT TOOL "1" LENGTH 30
RENAME TOOL "1" "D6R0.5-R"
EDIT TOOL "D6R0.5-R" NUMBER COMMANDFROMUI 4
EDIT TOOL "D6R0.5-R" HOLDER_COMPONENT ADD
EDIT TOOL "D6R0.5-R" OVERHANG 30
EDIT TOOL "D6R0.5-R" HOLDER_COMPONENT LOWERDIA 36
TOOL ACCEPT
FORM BLOCK
EDIT BLOCK RESETLIMIT 2
EDIT BLOCK RESET
EDIT BLOCK ZMIN 10.2 (此处在VB中可以改为底座高度变量+0.2高度余量)
EDIT BLOCK RESETLIMIT 4
EDIT BLOCK RESET
BLOCK ACCEPT
FORM FEEDRATE
EDIT RPM 6400
EDIT FRATE 3200
EDIT PRATE 1200
EDIT RSPEED 4000
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT RMOVES PLUNGE
EDIT ISTAZ 1
EDIT TOOLPATH SAFEAREA RESET
TOOLZHEIGHTS ACCEPT
FORM LEADLINK
EDIT TOOLPATH LEADS PLUNGEDIST 1
EDIT TOOLPATH LEADS LINK INCR
EDIT TOOLPATH LEADS LONGLINK INCR
EDIT TOOLPATH LEADS SAFELINK INCR
FORM PMLLEADINRAMP
EDIT TOOLPATH LEADS LEADIN RAMPOPT ZIGANGLE 2
EDIT TOOLPATH LEADS LEADIN RAMPOPT HEIGHT_INCREMENT 1
LEADINRAMP ACCEPT
LEADS ACCEPT
IMPORT TEMPLATE ENTITY TOOLPATH "Favourites\Offset-AreaClear-Model.ptf" FORM TOOLPATH
RENAME TOOLPATH "1" "D6R0.5-R-L"
EDIT RTOLERANCE 0.02
EDIT RTHICKNESS AXIAL_RADIAL ON
EDIT RTHICKNESS "0.2" (此处在VB中可以改为电极火花位变量+0.25料余量)
EDIT RTHICKNESS AXIAL "0.1"(此处在VB中可以改为电极火花位变量+0.15料余量,后面以此类推..)
EDIT OVER 3.5
EDIT ZHEIGHTS AUTOMATIC STEPDOWN 0.5
SET AREACLEAREXPERT
EDIT LMOVES RAMP
FORM RAMP
EDIT RAMP ZIGANGLE 2
RAMP ACCEPT
EDIT ALLOWTOOLOUTSIDEBLOCK OFF
EDIT FLAT_TOLERANCE 0.01
EDIT SLICEARCFIT ON
EDIT AREACLEAROFFSET SMOOTHING ON
EDIT AREACLEAROFFSET SMOOTHINGALLOWANCE 5
FORM LEADLINK
FORM PMLLEADINRAMP
EDIT TOOLPATH LEADS LEADIN RAMPOPT ZIGANGLE "2"
EDIT TOOLPATH LEADS LEADIN RAMPOPT HEIGHT_INCREMENT "0.8"
LEADINRAMP ACCEPT
LEADS ACCEPT
EDIT TOOLPATH "D6R0.5-R-L" REAPPLYFROMGUI
IMPORT TEMPLATE ENTITY TOOLPATH "Favourites\Constant-Z-Finishing.ptf" FORM TOOLPATH
RENAME TOOLPATH "1" "D6R0.5-R-S"
EDIT FTOLERANCE "0.02"
EDIT FTHICKNESS "0.2"
EDIT STEPDOWN 0.5
FORM LEADLINK
EDIT TOOLPATH LEADS LEADIN HARC
FORM PMLLEADINRAMP
LEADINRAMP CANCEL
EDIT TOOLPATH LEADS LEADIN ANGLE 90
EDIT TOOLPATH LEADS LEADIN LRAD 5
EDIT TOOLPATH LEADS LEADOUT COPY
EDIT TOOLPATH LEADS LINK THRESHOLD 36
EDIT TOOLPATH LEADS LINK SKIM
EDIT TOOLPATH LEADS OVERLAPDIST 0
LEADS ACCEPT
FORM BLOCK
EDIT BLOCK ZMIN UNLOCK
EDIT BLOCK ZMAX UNLOCK
EDIT BLOCK RESET
EDIT BLOCK ZMIN -0.2
EDIT BLOCK ZMAX 10
BLOCK ACCEPT
EDIT TOOLPATH "D6R0.5-R-S" REAPPLYFROMGUI
RESET ALL
CREATE TOOL ; BALLNOSED FORM TOOL
EDIT TOOL "1" DIAMETER 4
EDIT TOOL "1" LENGTH 20.0
RENAME TOOL "1" "R2-F"
EDIT TOOL "R2-F" NUMBER COMMANDFROMUI 16
EDIT TOOL "R2-F" SHANK_COMPONENT ADD
EDIT TOOL "R2-F" SHANK_COMPONENT LENGTH 3.73
EDIT TOOL "R2-F" SHANK_COMPONENT LOWERDIA 4
EDIT TOOL "R2-F" SHANK_COMPONENT UPPERDIA 6.0
EDIT TOOL "R2-F" SHANK_COMPONENT LENGTH 3.27
EDIT TOOL "R2-F" IMPORT_HOLDER FILEOPEN
"C:\dcam\POWERMILL-HOLD\CR\CR12_6_35.dgk"
EDIT TOOL "R2-F" OVERHANG 27
TOOL ACCEPT
FORM BLOCK
EDIT BLOCK RESET
EDIT BLOCK ZMIN 12.5
EDIT BLOCK RESETLIMIT 3
EDIT BLOCK RESET
BLOCK ACCEPT
CREATE BOUNDARY ; SHALLOW FORM BOUNDARY
RENAME BOUNDARY "1" "R2-F-H"
EDIT BOUNDARY "R2-F-H" SLOPE 50
EDIT BOUNDARY "R2-F-H" TOLERANCE .005
EDIT BOUNDARY "R2-F-H" THICKNESS -0.15
EDIT BOUNDARY "R2-F-H" THICKNESS ACCEPT EDIT BOUNDARY "R2-F-H" CALCULATE
EDIT BOUNDARY "R2-F-H" THICKNESS ACCEPT BOUNDARY ACCEPT
RENAME BOUNDARY "1" "R2-F-V"
EDIT BOUNDARY "R2-F-V" SLOPE 40
EDIT BOUNDARY "R2-F-V" TOLERANCE .005
EDIT BOUNDARY "R2-F-V" THICKNESS -0.15
EDIT BOUNDARY "R2-F-V" THICKNESS ACCEPT EDIT BOUNDARY "R2-F-V" CALCULATE
EDIT BOUNDARY "R2-F-V" THICKNESS ACCEPT BOUNDARY ACCEPT
FORM BLOCK
EDIT BLOCK ZMIN 10.5
BLOCK ACCEPT
FORM FEEDRATE
EDIT RPM 13000
EDIT FRATE 3000
EDIT PRATE 1600
EDIT RSPEED 4000
FEEDRATE ACCEPT
FORM FEEDRATE
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT RMOVES PLUNGE
EDIT ISTAZ 1
TOOLZHEIGHTS ACCEPT
28
发表于 2007-7-15 15:52:18 | 只看该作者
还有一半
RENAME TOOLPATH "1" "R2-F-H"
ACTIVATE BOUNDARY "R2-F-H"
EDIT FTOLERANCE ".005"
EDIT FTHICKNESS "-0.15"
EDIT FINRASTER STEPOVER "0.08"
FORM LEADLINK
LEADS ACCEPT
FORM BLOCK
BLOCK ACCEPT
EDIT TOOLPATH "R2-F-H" REAPPLYFROMGUI
RENAME TOOLPATH "1" "R2-F-V"
FORM LEADLINK
EDIT TOOLPATH LEADS LEADIN LRAD 2
EDIT TOOLPATH LEADS LINK THRESHOLD 6
LEADS ACCEPT
EDIT STEPDOWN 0.08
ACTIVATE BOUNDARY "R2-F-V"
EDIT BOUNDARYSIDE OUTSIDE
EDIT TOOLPATH "R2-F-V" REAPPLYFROMGUI
RESET ALL
FORM BLOCK
EDIT BLOCK RESET
EDIT BLOCK ZMAX 13.5
EDIT BLOCK RESET
BLOCK ACCEPT
FORM FEEDRATE
EDIT RPM 6400
EDIT FRATE 1400
EDIT PRATE 800
EDIT RSPEED 4000
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT RMOVES PLUNGE
EDIT ISTAZ 1
TOOLZHEIGHTS ACCEPT
FORM LEADLINK
LEADS ACCEPT
RENAME TOOL "1" "D6R0.5-F"
EDIT TOOL "D6R0.5-F" NUMBER COMMANDFROMUI 8
EDIT TOOL "D6R0.5-F" IMPORT_HOLDER FILEOPEN
EDIT TOOL "D6R0.5-F" OVERHANG 30
TOOL ACCEPT
RENAME TOOLPATH "1" "D6R0.5-F-V"
FORM LEADLINK
EDIT TOOLPATH LEADS LEADIN LRAD 3
EDIT TOOLPATH LEADS LINK THRESHOLD 30
LEADS ACCEPT
EDIT FTHICKNESS AXIAL "-0.15"
EDIT STEPDOWN 0.1
EDIT TOOLPATH "D6R0.5-F-V" REAPPLYFROMGUI
FORM BLOCK
EDIT BLOCK RESET
BLOCK ACCEPT
FORM FEEDRATE
EDIT RPM 6400
EDIT FRATE 600
EDIT PRATE 300
EDIT RSPEED 4000
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT RMOVES PLUNGE
EDIT ISTAZ 1
TOOLZHEIGHTS ACCEPT
FORM LEADLINK
LEADS ACCEPT
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI
"Finishing\Raster-Flat-Finishing.ptf"
RENAME TOOLPATH "1" "D6R0.5-F-F"
FORM BLOCK
EDIT BLOCK ZMIN 9
EDIT BLOCK ZMAX 11
EDIT BLOCK RESET
BLOCK ACCEPT
EDIT FTHICKNESS "0"
EDIT FTHICKNESS AXIAL "0"
EDIT RASTER_FLAT STEPOVER 4
EDIT RASTER_FLAT FLAT_TOLERANCE 0.01
EDIT RASTER_FLAT OUTSIDE_ALLOWANCE 0.6
EDIT RASTER_FLAT ALLOWTOOLOUTSIDEFLAT ON
EDIT RASTER_FLAT CUTDIR ANY
EDIT RASTER_FLAT SLICEARCFIT ON
EDIT TOOLPATH "D6R0.5-F-F" REAPPLYFROMGUI
"3D-Area-Clearance\Profile-AreaClear-Model.ptf"
RENAME TOOLPATH "1" "D6R0.5-F-S"
SET AREACLEAREXPERT
UNSET OUTSIDE
EDIT LMOVES PLUNGE
EDIT RTOLERANCE ".005"
EDIT RTHICKNESS "0"
EDIT ZHEIGHTS AUTOMATIC STEPDOWN "0.3"
EDIT PCUTDIR CLIMB
EDIT FINALPROFILEPASS ON
EDIT FINALPROFILEPASS ALLOWANCE 0.1
EDIT FLAT_TOLERANCE "0.01"
FORM BLOCK
EDIT BLOCK ZMIN 0
EDIT BLOCK ZMAX 0.2
BLOCK ACCEPT
EDIT TOOLPATH "D6R0.5-F-S" REAPPLYFROMGUI
BATCH PROCESS
EXPLORER SELECT Toolpath "Toolpath\D6R0.5-F-S" NEW
ACTIVATE TOOLPATH "D6R0.5-F-S"
FORM LEADLINK
EDIT TOOLPATH LEADS LEADIN ANGLE "90"
EDIT TOOLPATH LEADS LEADIN LRAD "3"
EDIT TOOLPATH LEADS LINK STRAIGHT
EDIT TOOLPATH LEADS LINK THRESHOLD "30"
PROCESS TPLEADS
LEADS ACCEPT
29
发表于 2007-7-15 17:00:19 | 只看该作者
感谢兄弟热心相助
30
发表于 2007-7-15 18:59:23 | 只看该作者
兄弟们牛呀,我只会很简单的,什么也不说,先顶了,
GMT+8, 2025-4-23 15:30 , Processed in 0.023627 second(s), 10 queries , Gzip On, Redis On.
