查看: 21227|回复: 11
[求助] 关于UG调用dll之后的撤销问题…………
发表于 2009-9-17 13:41:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在UG中画了一个圆柱,接着调用一个DLL(是一个生成四方块的dll),四方块的生成后,我在UG界面中执行了一次撤销操作,结果把圆柱也给撤销掉了!!按理说只是把四方块给撤销掉才对呀!这是怎么回事呢???
下面是我的代码:
        /* TODO: Add your application code here */
  UF_FEATURE_SIGN sign = UF_NULLSIGN;
        double block_orig[3] = {0.0,0.0,0.0};
        char *block_len[3] = {"1","2","3"};
        tag_t blk_obj;
        UF_MODL_create_block1(sign, block_orig, block_len, &blk_obj);
        /* Terminate the API environment */
        errorCode = UF_terminate();
我用别人做的DLL时,是不会撤销到我之前所做的模型的,只会撤销DLL生成的结果。是不是还要在C++中加入其他的代码才有这样的效果呀…………
希望路过的高手解答。小弟多谢啦!!!
发表于 2009-9-17 18:14:53 | 只看该作者
需要设UNDO,参考uf_undo.h头文件
发表于 2009-9-19 08:49:33 | 只看该作者
多谢 zale_lzj  兄的指点,问题已经解决……
现把代码贴出来:
        tag_t blk_obj;
        UF_UNDO_mark_id_t     mark_id;
                UF_UNDO_set_mark(UF_UNDO_visible, NULL, &mark_id);
头像被屏蔽
发表于 2009-9-19 16:54:45 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-10-3 19:46:20 | 只看该作者
Instructs every data manager which is logged on to set a mark.
Returns an identifier which the application can use to identify the
state of the data managers at the time the mark is set. Additionally,
the application can register a name by which this mark can later be
referenced.
Note:  The maximum number of undo marks in an Open API program is 100.
Environment: Internal  and  External
See Also:
History:
extern UFUNEXPORT int UF_UNDO_set_mark(
UF_UNDO_user_visibility_t visibility ,/* <I>
                                      The user visibility of this mark.
UF_UNDO_mark_name_t mark_name ,/* <I>
                               optional name for this mark. If NULL
                               then not used. If not NULL then must
                               be '\0' terminated. UF_UNDO copies this
                               name to some space of its own, therefore,
                               the caller may do whatever it wants with
                               'mark_name' after the call.
UF_UNDO_mark_id_t * mark_id  /* <O>
                             identifier associated with this mark.
发表于 2009-10-7 23:00:36 | 只看该作者
如果你使用BlockStyler创建界面的话就不用加MARK函数,因为会自动加上,
发表于 2009-10-9 09:20:04 | 只看该作者
学习了。。。
发表于 2009-10-13 23:09:05 | 只看该作者
在头文件里面加 uf_undo.h
char sUndoname[]="设置后退的提示";
UF_UNDO_set_mark(UF_UNDO_visible,sUndoname,&mark_id);
很简单的
发表于 2010-8-31 10:01:59 | 只看该作者
不错 ,学习了。。。
发表于 2010-11-7 00:22:19 | 只看该作者
谢谢!!!!!!!!!!!!!
GMT+8, 2025-4-21 05:59 , Processed in 0.025730 second(s), 12 queries , Gzip On, Redis On.
