[挑战题目100分] DMG 50V 五面(轴)加工后置处理程序开发
发表于 2003-10-16 09:56:55 | 只看该作者
the parts
发表于 2003-10-16 10:09:23 | 只看该作者
I want to calculate the angle when it is rotated to the tilted face.
  the MCS is on the tilted surface, and the origin is on the center point of the hole...
I want to get the I J K from the tool axis, so as to calculate the B C angle...
The CLSF:
TOOL PATH/D25R0.8_COPY,TOOL,D25R4.8CEM
TLDATA/MILL,25.0000,0.0000,50.0000,0.0000,0.0000
MSYS/-49.5037,110.6111,4.6673,-0.2336063,0.4305111,-0.8718304,-0.1114245,-0.9025853,-0.4158418
PAINT/PATH
PAINT/SPEED,10
PAINT/COLOR,186
RAPID
GOTO/50.4822,23.5571,0.0000,0.0000000,0.0000000,1.0000000
To test the I J K
proc  MOM_start_of_path {} {
#_______________________________________________________________________________
# This procedure is executed at the begining of each path in the task
# It gets called after all the general parameters of the path are loaded
# like the path name and the tool name.
         global mom_path_name
         global mom_tool_name
         global i j k
         global mom_tool_axis
         global mom_prev_tool_axis
         MOM_output_literal "$mom_tool_axis(0), $mom_tool_axis(1), $mom_tool_axis(2)"
         MOM_output_literal "$mom_prev_tool_axis(0), $mom_prev_tool_axis(1), $mom_prev_tool_axis(2)"
         CHECK_OPER_TYPE
and the Test result
0 BEGIN PGM UG_TRY MM
1 -0.87183043658199078, -0.41584178691117041, 0.25881904510252024
2 0.00000000000000000, 0.00000000000000000, 1.00000000000000000
3 L M129
And I get the I J K of the normal vector of the surface is:
I 0.416   J  0.2588   K  -0.8718
what is the problem with the tool axis I J K?
How to utilize these to calculated the B and C angle?  I just want the 5-sided postprocessor
23
发表于 2003-10-16 11:07:40 | 只看该作者
为什么要计算MSYS的矢量呢?
看你的CLS文件,是三轴垂直的:
   RAPID
24
发表于 2003-10-16 11:25:10 | 只看该作者
wave wrote:
为什么要计算MSYS的矢量呢?
  看你的CLS文件,是三轴垂直的:
     RAPID
加工是在当前的加工坐标系, 故 0   0   1, 当前的加工坐标系是通过旋转和平移绝对坐标系得到的,  如前面的MSYS, 我想知道如何计算B 轴和C 轴的旋转角度从而得到当前的加工坐标
25
发表于 2003-10-16 11:31:53 | 只看该作者
如图:
发表于 2003-10-16 11:37:25 | 只看该作者
一次安装先铣A面, 然后旋转, 使B面水平,  铣B面, ......
如何计算 B 和 C 要转多少?
要不要我把零件发给你?
多谢了!
27
发表于 2003-10-16 12:40:21 | 只看该作者
旋转坐标系干什么?
28
发表于 2003-10-16 13:09:49 | 只看该作者
其实就是要转B轴 (45度轴) 和C 轴( 工作台中心), 使B 面成水平(与刀轴垂直), 加工时需要刀轴与被加工面垂直.
      简单说就是把B面 从斜面转成水平面 ? ( 装夹时以 与A面平行的底面定位).
29
发表于 2003-10-16 14:53:42 | 只看该作者
jinly wrote:
如图:
按此图装夹.Z轴向上,右側的孔如何做?
30
发表于 2003-10-16 14:54:16 | 只看该作者
  如何计算 B 和 C 要转多少?
  要不要我把零件发给你?
  多谢了!
发文件吧
GMT+8, 2025-9-18 17:10 , Processed in 0.047678 second(s), 11 queries , Gzip On, Redis On.
