【原创】曲柄压力机运动分析
发表于 2012-3-29 22:16:57 | 只看该作者
我做过了,很厉害!
谢谢!!
132
发表于 2013-4-9 11:13:33 | 只看该作者
来看仿真怎么弄
133
发表于 2013-4-9 11:18:23 | 只看该作者
对呀好像没附件啊
134
发表于 2013-5-21 16:57:10 | 只看该作者
我在做柴油机曲柄连杆机构,看到这个我感动的要哭了,啊啊啊
135
发表于 2013-6-1 13:52:19 | 只看该作者
顶一个
136
发表于 2013-6-16 12:56:18 | 只看该作者
真是个才子啊,佩服佩服。。。
137
发表于 2014-6-12 21:26:42 | 只看该作者
版主:
       你好,我是Adams初学者!向你请教一个问题: 在一六轴机器人上,先是在其末端按规划好的轨迹添加一“一般点驱动”,让末端走到目标点,然后在机器臂各转动关节上建立相应的measure,以得出其关节角的变化曲线,再针对各angle变化曲线建立相应的样条(spline_1~spline_6),再根据你之前所提示的样条函数AKISPL( 1st_Indep_Var , 2nd_Indep_Var , Spline_Name , Deriv_Order)函数的应用,在各关节转动副上一一添加驱动,为什么仿真结果差别那么大,还有很多Warning。麻烦版主给我详细介绍下AKISPL函数的应用好吗?感激不尽....!
<以下是我课题中的问题,请版主帮忙查阅下其中问题,谢谢。。。!>
各关节驱动是这样的:AKISPL(time,0,spline_1,0)~~AKISPL(time,0,spline_6,0);(至于后边是否还要乘以个time,我不知用意何在?求版主指教!)
仿真结果(warnings):
WARNING:    An out-of-range X value has been used in the spline calculation.    Extrapolation is required for the SPLINE Knee.drive_2.
    The X value ( -1.0E-05 ) should be between 0.0 and 0.17453.
    Extrapolation is required for the SPLINE Knee.drive_3.
   Extrapolation is required for the SPLINE Knee.drive_4.
   Extrapolation is required for the SPLINE Knee.drive_5.
   Extrapolation is required for the SPLINE Knee.drive_6.
   The X value ( 0.20 ) should be between 0.0 and 0.17453.
WARNING:    Adams will no longer warn for any out-of-range violations for
   SPLINE Knee.drive_2. Out-of-range X and Z values of spline have been used more
   than 5 times.
   SPLINE Knee.drive_3. Out-of-range X and Z values of spline have been used more
   than 5 times.
   SPLINE Knee.drive_4. Out-of-range X and Z values of spline have been used more
   than 5 times.
   SPLINE Knee.drive_5. Out-of-range X and Z values of spline have been used more
   than 5 times.
   SPLINE Knee.drive_6. Out-of-range X and Z values of spline have been used more
   than 5 times.
   than 5 times.
   than 5 times.
   than 5 times.
   than 5 times.
   than 5 times.
138
发表于 2014-12-15 18:38:03 | 只看该作者
多谢楼主
139
发表于 2016-3-19 21:09:18 | 只看该作者
学习了,感谢分享
140
发表于 2018-9-16 17:07:30 | 只看该作者
附件在几楼呢
GMT+8, 2025-4-25 00:53 , Processed in 0.043118 second(s), 12 queries , Gzip On, Redis On.
