结构设计改良集锦
发表于 2005-8-25 19:23:53 | 只看该作者
go on
112
发表于 2005-8-26 16:07:09 | 只看该作者
建议竹斑加分啊!
113
发表于 2005-8-27 11:36:58 | 只看该作者
关键看用途和使用环境才能最后确选用那种!
114
发表于 2005-9-15 17:04:58 | 只看该作者
受教,收获不少
115
发表于 2005-9-15 19:23:23 | 只看该作者
顶啊
116
发表于 2005-9-15 21:46:53 | 只看该作者
不错
117
发表于 2005-9-17 00:44:01 | 只看该作者
OK,GOOD!!
好样的,英语水平有所提高
118
发表于 2005-9-17 17:56:15 | 只看该作者
Certainly nobody will doubt about the value of your proposal, but, why didn't you just study carefully the instruction sheet before use? we can safely say all the products are designed for special people. you don't like it, but it doesn't necessarily follows that other people do not like it.
119
发表于 2006-8-3 19:32:48 | 只看该作者
Don't press any buttons underwater!
By Cari Carothers
I've been trying to get into shape so I could start doing triathlons -- athletic events composed of swimming, cycling and running. I purchased a nice sport watch, a "Triathlon" model, so I could time myself in the pool and confirm I was counting the laps correctly. After just a few workouts, the watch filled up with water! I took it back and they happily replaced it, saying that I must have accidentally pushed the buttons under water!
The watch was water resistant to 100 m. I looked at the instruction booklet that came with the watch. On the last page of the instructions was printed...
WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER
This limitation seemed ridiculous since using the watch to keep track of laps in the pool would involve pressing buttons on the watch while swimming.
Design Suggestion
The athelete is likely to press the watch buttons underwater because the warning isn't obvious. If a warning sticker was placed on the watch, it would be more obvious.
Of course, a better solution would be to design the watch to allow the buttons to be pressed while swimming, without ruining the watch. Some other brands of watches allow this.
120
发表于 2006-8-3 19:35:38 | 只看该作者
WATCH PIC
GMT+8, 2025-4-27 19:54 , Processed in 0.024972 second(s), 11 queries , Gzip On, Redis On.
