UG NX 2.0 WHAT'S NEW
发表于 2003-3-9 11:36:49 | 只看该作者
Multiple Selection
What is it?
Multiple Selection functionality allows you to select multiple features at a time for removing from or appending to a feature group by using the Class Selection dialog.
Why should I use it?
You should use this feature to save time when you need to remove or append several features at a time from a feature group, instead of removing or appending them one by one.
Where do I find it?
Manufacturing -> edit a Feature Group -> Feature Selection -> Class Selection
发表于 2003-3-9 11:37:03 | 只看该作者
Inch and Metric Availability Within Tool Query
What is it?
It is possible to search for metric tools when you are in an inch part file and vise-versa.
Use this option if you want to use a metric tool while you are in an inch part file or vice-versa, you should use this option to help you select the correct tool library.
Where do I find it?
Manufacturing -> Edit a Holemaking operation ->Tool Query
User Defined Cycles
What is it?
User Defined Cycles allows you to define new cycles or add more parameters to the system cycles.
Use this option when none of the system cycles provides the cycle you need, and you need to define and use your own cycles.
Where do I find it?
In the ude.cdl file.
93
发表于 2003-3-9 11:37:53 | 只看该作者
Linked Posts
What is it?
In Post Builder you now have the option to link posts. You link posts when you are supporting complex machine tools that require multiple types of tool paths and several postprocessors. When supporting several postprocessors for one machine you must link the postprocessors so that they can run together smoothly.
Use the Linked Post feature in Post Builder to link posts together so they are integrated with the output of events from Unigraphics NX Manufacturing.
Where do I find it?
Post Builder provides a simple user interface that allows for extensive customization. Use this feature by selecting the Linked Post option on the General Machine Parameters dialog.
Mill/Turn
What is it?
The new Mill/Turn option in Post Builder allows you to create and edit postprocessors for Mill/Turn Machine Tools.
Use the Mill/Turn feature in Post Builder to create posts that are integrated with the output of events from Unigraphics NX Manufacturing.
Where do I find it?
In Post Builder--> Create New Post--> select the 3-Axis Mill/Turn (XZC) option.
  Wire EDM
What is it?
The new Wire EDM option in Postbuilder allows you to create and edit postprocessors for Wire EDM Machine Tools.
Use the Wire EDM feature in Post Builder to create posts that are integrated with the output of events from Unigraphics NX Manufacturing.
Where do I find it?
Postbuilder-->Create New--> Wire EDM option.
94
发表于 2003-3-9 11:38:29 | 只看该作者
Dynamic MCS Interaction
What is it?
When you are editing the MCS you can now use dynamic interaction on the graphics window to position or rotate the MCS. This enhancement uses the same interaction as the dynamic WCS.
It is a quicker and more convenient way to orient the MCS, giving you direct feedback.
Where do I find it?
Edit the MCS from the Operation Navigator and the system displays handles for the MCS in the graphics window.
  Palette Support
What is it?
You can now use palettes to access Manufacturing  templates used for initialization of new setups.
It抯 a simpler and more convenient way to initialize part files with Manufacturing information than choosing a configuration and setup, or selecting from the setup library.
Where do I find it?
To add a new Manufacturing palette to the resource bar, go to CAM Preferences dialog--> Configuration tab --> Add Palette button--> select Inch and/or Metric palette. Once you have done this, you can find the Manufacturing palette(s) in the resource bar area while in Gateway, Modeling or Manufacturing.
  Browse Button for Post Builder
What is it?
The dialog used to post process an operation now allows you to browse for more post processor files (*.pui file) in addition to the ones already available in the list.
It抯 a simple way of accessing additional post processor files without having to modify the configuration files.
Where do I find it?
The functionality can be found using the Browse button below the list box in the post process dialog.
What is it?
Where do I find it?
95
发表于 2003-3-9 11:39:34 | 只看该作者
Z Level with Reference Tool
What is it?
With Z Level Reference Tool, you can finish-mill corners using Z level cuts. The cuts are similar to Z Level Profile operations, but limited only to corner areas that a defined previous tool could not reach due to its diameter and corner radius.
Use Z Level Reference Tool when you want to remove a small amount of blank material  from corner areas. This operation would typically follow a finish operation by a larger tool, which could not finish the corner areas.
Where do I find it?
Manufacturing --> Create New Operation --> Mill Contour --> Z Reference Tool.  You can use this in existing Z Level profile operations by adding the previous tool item with customize dialog.
Automatic Wall Identification in Face Milling
What is it?
With Automatic Wall Identification, the Face Milling processor automatically recognizes and applies wall stock to faces adjacent to the selected cut area faces, satisfying the documented wall criteria.
Use Automatic Wall Identification when cut area faces have adjacent walls that can be automatically recognized using the documented wall criteria.  This saves time because you can apply wall stock to the necessary faces without having to select the faces individually.
Where do I find it?
Automatic Wall Identification is available on the Face Milling dialog.
Cut Area in Face Milling
What is it?
With Cut Area, you can use flat cut area faces to define the machined faces for a Face Milling operation.
Use Cut Area when face geometry alone, without boundaries, is sufficient to define the machined faces on a part body, or when the machined faces have finished walls requiring a unique stock.
Where do I find it?
You can define Cut Area inside a Face Milling operation or inherit it from a MILL_AREA geometry group.
Pre-Select Wall Geometry in Face Milling
What is it?
You can use Pre-Select Wall Geometry to initialize wall geometry based upon the cut area faces. You retain the ability to remove, edit or append items from Wall Geometry.
Use this functionality when most, but not all, of the wall geometry adjacent to the cut area faces can be selected using the documented criteria for Automatic Wall Identification.
Where do I find it?
You can find the Pre-Select button inside the Select/Edit dialog for Wall Geometry.
Wall Stock and Wall Geometry in Face Milling Operations
What is it?
Now, you can select faces on the part body (other than the faces being machined) as wall geometry and apply a unique wall stock to those faces in place of part stock.
Use wall stock and wall geometry when you are machining faces that have finished walls requiring a unique stock other than part stock.
Where do I find it?
Select wall geometry inside a face milling operation, or inherit from a MILL_AREA geometry group.
Define wall stock in the Cutting Parameters dialog for a face milling operation.
  Zig Zag 3D Stepover
What is it?
With Zig Zag 3D Stepover, you can direct the system to calculate the patterns to maintain a specified distance between tool paths. This distance can be either in the plane normal to the tool axis or the actual distance measured between the nearest tool path motions across successive passes.  With this pattern you specify a cut type in successive parallel cuts.   This adds to the existing functionality of Follow Periphery introduced in Unigraphics NX1.
Use Zig Zag 3D Stepover when you are machining parts that have steep and non-steep regions over the part surfaces using the parallel pattern.  Use this to control scallop height, especially in steep areas, but maintain the maximum stepover in 3D, measured along the part.
Where do I find it?
Area Milling Operations --> Drive Parameters dialog.  Change Apply Stepover to On Part.
Tangential Extensions
What is it?
With Tangential Extensions, you can extend tool paths tangentially past the external edges of the cut area.
Use Tangential Extensions when you want to machine excess material around the part. You can also use it to add cutting moves to the start and end of tool path passes to ensure that the tool smoothly enters and exits the part.
Where do I find it?
Tangential Extensions is located on the Cutting Parameters dialog for Flowcut, Area Mill, and Zlevel Profile operations.
2D Contact Contour
What is it?
With 2D Contact Contour, you can select the tracking point (as indicated by the number one in Figure 1) to output the contact contour tool path.
Figure 1
Use this when you would like to output the specific tracking point to the tool path.
Where do I find it?
The Output Contact Data toggle is located in Machine Control --> Cutter Compensation dialog.
发表于 2003-3-9 11:39:53 | 只看该作者
3D Contact Output
What is it?
With 3D Contact Output,  you can optionally output the 3-D contact data, including the surface normals,  in the Tool paths for Surface Contouring operations.
Use this when you desire 3-D contact data output for finishing operations, such as for 3-D Cutter Compensation.
Where do I find it?
The Output Contact Data toggle is in the Machine Control dialog of Surface Contouring.
97
发表于 2003-3-9 11:40:08 | 只看该作者
Trochoidal Cut Pattern
What is it?
Trochoidal cutting is a method of milling by cutting in small loops along a path (see number one in Figure 1), resembling a stretched-out spring. When the cutter is embedded in too much material, it will use trochoidal cutting to avoid cutting excessive material.
发表于 2003-3-9 11:40:30 | 只看该作者
Figure 1:  Compare cutting a straight slot with Trochoidal Cut Pattern (number 1) to cutting it using a conventional cut pattern (number 2)
Trochoidal is useful in high speed milling applications, where you want to avoid cutting with the cutter completely embedded, and limit excessive stepover.
Figure 2:  Trochoidal stepover (number 1) and path (number 2)
Where do I find it?
In Planar, Cavity, and Face Milling, Trochoidal is a new cut pattern. To adjust the parameters, from the operation dialog, Cutting --> Trochoidal cutting .
发表于 2003-3-9 11:41:09 | 只看该作者
Irregular Shaped Faces
What is it?
When the portion of the cut region between consecutive Zig-Zag passes is concave, the stepover motion between passes uses the shortest, most direct path possible without violating or dragging the tool over the part.
Direct motions are automatically substituted wherever the region is concave to create more direct stepovers.
Where do I find it?
Direct Stepovers are automatically output for all face milling operation that use a Zig-Zag cut type.
Text Engraving
What is it?
With Text Engraving, you can machine drafting text  in Planar Milling and Surface Contouring.
Use Text Engraving when you want to engrave text directly on the part. This is useful for things like part numbers and mold cavity ID numbers.
Where do I find it?
For planar text, go to create operation, select the mill_planar type --> planar_text operation. For contoured text, select the mill_contour type --> contour_text operation. To create a group, go to create geometry, mill_planar type --> mill_text group. To create a note, go to Application --> Drafting, turn off Display Drawing on the drafting toolbar, and select Annotation Editor, enter your text, and create without leader.
IPW in Fixed Axis Milling
What is it?
To increase performance, there is a preference for saving the IPW in separate part files.  For each operation that uses IPW, this will create a component part in your assembly that contains the faceted body IPW.
Use this to increase the processing speed for regenerating operations, and to distribute the data among several part files.
Where do I find it?
For this preference, navigate as follows:    Preferences --> Manufacturing --> Configuration.
The parts are named <part name>_ipw_<operation name>.prt.
The reference set is <operation name>
Corner Rough
What is it?
With Corner Rough you can rough-mill corners using Z level cuts. The cuts are similar to Cavity Mill operations, but limited only to corner areas that a defined previous tool could not reach due to its diameter and corner radius.
Use this operation when you want to remove blank material from corner areas. This operation typically follows a rough cavity milling operation by a larger tool, which could not reach the corner areas.
Where do I find it?
Manufacturing --> Create New Operation -->  Mill Contour --> Corner Rough.
100
发表于 2003-3-9 11:42:03 | 只看该作者
File Open and Save As for Neutral Files
What is it?
Unigraphics NX now has filters for IGES, STEP, DXF, and DWG files on the File-->Open and File-->Save As dialogs.  These filters allow you to open neutral files such as IGES files from the File-->Open dialog.
The new filters will allow you to easily use foreign data in Unigraphics NX for design, machining, CAE, Rapid Prototyping, etc.
Where do I find it?
File --> Open
File --> Save As
CATIA V4 Solid and Sheet Body Translation
What is it?
The CATIA V4 solid and sheet body translator will read CATIA V4 model files and CATIA V4 export files.  The translator will also write out Unigraphics NX solid and sheet bodies to a CATIA V4 model file.
This translator supports the import of CATIA files from version 4.1.x to 4.2.0.
The CATIA V4 translator will allow you to easily make use of CATIA geometry in Unigraphics NX for design, machining, CAE, Rapid Prototyping, etc.
Where do I find it?
File --> Open or Save As
File --> Import --> CATIA V4 Solids or Part dialog
File --> Export --> CATIA V4 Solids
Assemblies --> Components --> Add Existing
Assemblies --> Components --> Substitute Component dialog
You can also simply drag and drop a CATIA V4 model file into the graphics window of Unigraphics NX 2.  If there are no other parts open, the translator will convert the CATIA V4 model file and open it in Unigraphics NX.  If you already have another part open, the translator will convert the CATIA V4 model file and open it as a component.
GMT+8, 2025-4-28 09:31 , Processed in 0.024072 second(s), 9 queries , Gzip On, Redis On.
