UG NX 2.0 WHAT'S NEW
发表于 2003-3-9 11:31:22 | 只看该作者
Annotation Preferences
What is it?
The following are improvements to Annotation Preferences:
Adds property pages to the Annotation Preferences dialog.
Changes the Annotation Preferences dialog so that it only sets global parameters – when invoked from the Preferences menu.
Modifies the new Edit->Annotation Style dialog to use property pages and support Action->Object and Object->Action.
Supports application-supplied input/output of preference values.
Displays property pages common to objects selected.
Why should I use it?
Use the new functionality to quickly and easily distinguish settings for global preferences and specific objects.
Where do I find it?
Choose Preferences-> Annotation for Setting global annotation preferences.
Choose Edit-> Style to set annotation preferences for selected objects.
62
发表于 2003-3-9 11:31:29 | 只看该作者
Parts Lists
What is it?
Parts list is a new function that replaces the previous parts list for creating a table containing a list of parts in an assembly. Many enhancements have been added from the old parts list including a brand new user interface.
To use this function, create one or more parts lists at any time during the creation of your assembly. The parts list can be made to automatically update as your assembly grows or update on demand. Individual piece numbers can either be locked or renumbered as needed. Automatic callouts can also be generated and updated as the parts list updates.
Parts lists provide an easy way for you to create a bill of materials for your assembly. It can be easily customized using a large variety of options.
Where do I find it?
Choose the "arts Lists" folder on the "Tables" palette.
63
发表于 2003-3-9 11:31:36 | 只看该作者
Snap Point in Drafting
What is it?
Drafting now uses Snap Point as the common point tool for all drafting functions. Whenever the Drafting functionality requires you to pick a point, the snap point toolbar displays on the graphic screen or in the toolbar area.
You use Snap Point as a consistent way to implement the point method across all Drafting applications.
Where do I find it?
You can find Snap Point throughout the Drafting interface.
64
发表于 2003-3-9 11:31:42 | 只看该作者
Dimension User Interface
What is it?
The dimension user interface has the following improvements:
A compact set of icon options located in the upper-left corner of the graphics window replaces the large dimensions dialog.
You can change preferences or add/edit single line appended text with an MB3 pop-up menu while you rubberband a dimension during creation or when you edit a dimension.
Dynamic input boxes display in the graphics window at the location where you create or edit a dimension and let you change preferences or add/edit single line appended text.
You can use Single-key accelerators for most common functions.
Use the new interface to create or edit dimensions while maintaining focus on the graphics window.
Where do I find it?
Choose Insert-> Dimension or choose a dimension type from the dimension toolbar.
65
发表于 2003-3-9 11:31:50 | 只看该作者
Text Creation
What is it?
A new, streamlined Annotation Editor allows you to create notes, labels, and GD&T symbols with emphasis on direct manipulation and less obtrusive user interface components. The interface is faster and easier to use and provides reduced eye and mouse movement.
The new user interface provides:
A simple multi-line text input field that follows the cursor so that you can create or edit the note more directly on the graphics window.
A set of on-screen icon options to access lettering style settings and drafting or GD&T symbols, and to provide seamless access to the full Annotation Editor dialog.
Inferred origin capabilities that allow you to align a note, and to create labels or GD&T symbols with simple leaders through direct manipulation and inferencing without the need for a dialog.
Use object-action or action-object methods to create or edit streamlined text as follows:
Choose the Annotation Editor toolbar icon and immediately begin typing note text and click to place the note. Passing the cursor over another annotation with no additional clicks before placement provides a simple, rapid means of aligning a note to annotation. You can place the same note again by clicking on a new placement location.
Double click on a note, label, or GD&T symbol to edit it. The streamlined note text field is automatically sized to the contents of the selected note. As you edit the note text, the graphics window display updates continuously. The changes are implicitly accepted, no Apply step is required. If you make a mistake you can simply correct it, or use Undo to revert to the original note text.
To create a label with a simple leader, simply press mouse button 1 and drag to initiate leader creation, then click to place the note with the leader. If you initiate the leader creation over another object, the leader type will be inferred.
To edit a series of annotations, Choose Edit-> Text. You can then select a note, edit the text, select the next note, and edit. Each time you select a note, the text input field resizes to the selected note.
Use the Annotation Editor streamlined create / text methods to quickly and easily edit annotation, keep attention and work focused on the drawing with less intrusion from the user interface.
Where do I find it?
The access methods for the Annotation Editor in the new streamlined create and edit modes are:
Insert-> Annotation or the Insert Annotation icon on the Drafting Annotation toolbar
Edit-> Text ( action-object or object-action)
Edit-> Drafting Object (object-action for notes, labels, and GD&T Symbols only)
MB3-> Edit Text (object-action editing for many annotations (not dimensions)
MB3-> Edit Appended Text (object-action for dimensions only)
66
发表于 2003-3-9 11:31:57 | 只看该作者
Tabular Notes
What is it?
A new interface makes creating and editing tabular notes easier and provides the following enhancements:
The ability to merge groups of cells.
The ability to break a single tabular note into multiple sections that can be individually placed on drawings.
Associative importing of spreadsheet information
Templates for creation
Cell fit methods
Color/Font/Width settings for cell text and grid lines
To use this capability, you first create a new tabular note containing the rows and columns of information you want. Then you can edit it by selecting it and using various MB3 functions.
The new interface makes tabular notes easier to use. Merging cells allows you to make tables that have large common rectangular areas of cells that appear as a single cell. Templates allow you to create a tabular note using a pre-defined tabular note as a template.
Where do I find it?
In the Tabular Notes folder on the Tables palette.
67
发表于 2003-3-9 11:32:04 | 只看该作者
UI Layout Enhancement
What is it?
Modifications to the Drafting User Interface layout provides a more useful set of options applicable to drafting objects.
Removal of Menu Options
Menu options that are unavailable during the display of a drawing were removed. These changes affect the following menus:
File
Edit
View
Insert
Tools
Drawing
Assemblies
WCS
Analysis
Use the streamlined applicable menus to choose drawing options.
Where do I find it?
Choose Application-> Drafting.
68
发表于 2003-3-9 11:32:13 | 只看该作者
View Display Preference Enhancement
What is it?
Enhancements to view display preferences are as follows:
Changes the View Preferences dialog so that it is used only to set global view display preferences
Adds property pages to the View Preferences dialog
Uses the same dialog to edit selected views’ style.
Adds a new Section Components action button to the View Preferences dialog and the Edit->View Style dialog.
Sets view parameters for selected views using the Edit->View Style dialog.
Saves global view preference settings with each part.
You the new interface for greater efficiency.
Where do I find it?
Choose Preferences-> View Display or access the on screen input icons.
Choose Edit-> View Style to set view parameters for selected views.
69
发表于 2003-3-9 11:32:25 | 只看该作者
Views in Global Select
What is it?
The following are enhancements for views and drawings:
You can now select drawing views and sheets with global selection.
MB3 pop-up menus appear for single and multiple selected views or sheets.
Drawing view and sheet borders prehighlight and highlight during selection using standard colors.
The following dialogs are replaced or augmented:
Dialog
  Alternative
Remove Views
  Edit-> Delete. You can only delete views with Edit-> Delete.
Align View
  Graphical feedback during Move Object Origin or move object origin with graphical alignment feedback.
Move/Copy
  Move Object Origin and Cut/Copy/Paste.
Style
  Edit View and Preferences -> View Display.
Graphical View Selection replaces view lists in the following dialogs:
Break-out Section
Edit View Dependent
Broken View
Use the new global selection functionality to increase your efficiency.
Where do I find it?
70
发表于 2003-3-9 11:32:36 | 只看该作者
Circle-U Symbol
What is it?
You can use the new circle-U symbol to mark unequally-disposed tolerance zones for profile tolerances.
If you want the circle-U symbol to appear on the Tolerance Editor, set the Gdt_allowCircleU customer default to yes. To use the circle-U symbol, toggle it ON in the Tolerance Editor when you input the outward portion of the unequally-disposed tolerance zone.
The latest proposed versions of the ASME Y14.5 and Y14.41 tolerancing standards plan support for this new symbol.
Where do I find it?
On the Profile Options pane of the Tolerance Editor
GMT+8, 2025-9-18 14:37 , Processed in 0.107538 second(s), 9 queries , Gzip On, Redis On.
