9.综合练习-2 模仁设计 - CimatronE 型腔模具设计与加工培训教程
2014-7-17 11:20| 查看: 32265| 评论: 0|来自: 思美创
摘要: 第二部分-模仁 设计.1. 创建工作零件—模仁(mold inserts).基本操作顺序是: 型芯和行腔已经存在于模架中.在这里只是调整其尺寸.然后将工作零件型面和分型面从分型子装配转移到工作零件(Mold inserts)中 使用分型面切 ...
Hide the parting surfaces that do not touch the cavity (the slider's parting surfaces)
隐藏没有接触行腔的分型面(滑块分型面)
Show the Cavity Insert 显示行腔镶件
Activate the Parting sub assembly 启动分型子装配
Open the Export Parting Faces tool from the Xelerated MoldDesign
Guide 从模具设计向导中打开输出分型面(Export Parting Faces)命令
Change the option Pick Faces by Indicating Split Directions to Free Selection 改变拾 取模式通过制定分型方向拾取为
自由拾取
Use pick by box to select all faces Note that only parting surfaces where selected 通过框选,选择所 有曲面(只有分型面被选择到).
The yellow curves represent the expected stitch result. We should
make sure it is correct and sits on the parting line 黄色曲线代表要缝合的结果,要
确保其正确并位于分型在线.
Click the middle mouse button (Exit) to move to the next stage 点击鼠标中键(推出) 转到下一步.
A real stitch operation is now created and the yellow curve you see now is the real open curve of the stitched parting surface 自动进行缝合操作,黄色的曲线变为缝 合后分型面的开方边曲线.
Keep the Cut option so that the cavity insert will be cut with the parting surface 保 持切割(Cut)选项,以使得行腔被分型面自动切割
Click the Preview button and make sure the result is correct for a cavity 单击预览
(Preview)按钮,
If it isn't – flip the direction arrow.
Make sure Max. Gap = 0.02 mm
确认行腔结果是否正确.如果不正确,切换箭头方向.切割是最大间隙 Max. Gap =
0.02 mm
Right now we have many open quilts in our part. We will close them all into a single solid 零件中含有许多开放的面体,现在通过缝合使之变成封闭实体.
Open the Stitch tool 打开缝合工具
Select all entities (pick by box or select all)选择所有体素,单击确认(OK) Click OK
GMT+8, 2025-4-25 15:51 , Processed in 0.022214 second(s), 11 queries , Gzip On, Redis On.
