9.综合练习-2 模仁设计 - CimatronE 型腔模具设计与加工培训教程
2014-7-17 11:20| 查看: 32222| 评论: 0|来自: 思美创
摘要: 第二部分-模仁 设计.1. 创建工作零件—模仁(mold inserts).基本操作顺序是: 型芯和行腔已经存在于模架中.在这里只是调整其尺寸.然后将工作零件型面和分型面从分型子装配转移到工作零件(Mold inserts)中 使用分型面切 ...
We want to make sure the object we have is a closed solid 为了确认物 体是封闭实体.切换到物体(Object)过滤器.把光标放到几何体,看看屏 幕下方的信息栏,显示为封闭实体(Closed Object)
Switch to object filter
Put the cursor over the body
Look at the information area at the bottom of the screen. The 2nd box indicates if the highlighted object is a closed or an open solid. In this case it should say Closed Object.
If the object is open you must look for the open area using the Analyze >> Entity Information tool on the object,
and then from it selects the Open Edges option
After the area of open edges was located – you must change the parting surface within the parting surface part to fix the problem, and edit the Export Parting Surface feature if required 如果物体时开放的,要通过分析(Analyze) >> 体素信息 (Entity Information).选择开放边(Open Edges)选项.如果发现开放边的区域,要到分 型面零件中修改分型面来修复问题,必要时编辑输出分型面特征
Most of the faces on the top of the insert are on the same plane, but they were cut so that the parting surface is right for the slider 行腔上表面大部分面位于同一平面 上,但是被切割成多张面.对滑块来说这是对的.我们也可以通过组合曲面把他们 变成单一面.(不一定必须要组合,可以保持原来状态)
We will now combine them into a single face.
Note that this is not a must. We can work with it as is.
Open the Faces >> Composite Face tool Select all the planer top faces 打开曲面 (Faces) >>组合曲面( Composite Face)中键 退出,单击确认键完成组合操作
5. 重复步骤 2\3\4,完成型芯侧的处理过程
结果应该如下图所示:
6. 最后来生成滑块的工作零件. 创建滑块子装配
启动主装配
打开装配(Assembly) >>添加新部件 (Add New Component)
选择装配档 单击确认(OK) 命名为: Sliders
使用选项放置在装配坐标系上( On Assembly UCS),单击确认(OK)
GMT+8, 2025-4-4 02:28 , Processed in 0.015852 second(s), 9 queries , Gzip On, Redis On.
